Hi guys newbie here,
Can somebody advise what the dashboard light is in the bottom left corner (looks like a box with a key in it)I ve got a 406 hdi exec 03 plate,and whats the cure for it
Thanks guys
406 Dashboard light
- 2.0 Turbo
Re: 406 Dashboard light
its the immobiliser light try changing the batteries in your key fob they might be running low
Is the car running o.k. or is it dead?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
- Newbie
Thanks for that,
Cars running as per normal,
Thought it might be a problem with the alarm, at least once a week it has a mad 5 mins and goes off for fun when i lock the car, it even goes off when i shut the door and dont lock it,then its ok for a week.
- Newbie
Thanks for the reply guys,
Thought i had it cured by taking the battery lead off, its been ok all day up and running, just looked at it and the indicators are flashing but the alarm is not sounding. Its nearly 24 hours since it started last night, it worked fine all day seems it only starts at night, any ideas, am going changing batteries in key fob in morn.
I'd say the car battery is low. Failing that get the fault codes on the BSI read...
Mine was flashing yellow lights during the night, turned out to be a low battery and also the car thinks the bonnet is open sometimes (bonnet sensor) haven't found this yet though to replace it!
If i lock it by the key, its fine. I haven't tried locking it on the fob since it happened as the bonnet sensor will more than likely set it off again
- Newbie
Thanks rlees,
I am tryin that tonight,(fingers crossed).
Derek
Derek
