cost cutting,
My Renault as got a few bits missing its sposed to have,
altho idont fancy all this junk tho -im glad its missing, no auto lights or this voice synth junk, perhaps the 1st buyer got a set of fancy mud flaps or carpet mats instead
I'm not talking to you...lozz wrote:ive seen someone with 19s on one it looks daft
Only if you get your tyre sizes wrong. You can increase the size of the rim without increasing the diameter of the tyre - means you have less rubber between road and rim (so the ride is a bit rougher) but there is basically no change to your speedo.FarmerPug wrote:the incorrect speedo is a valid point
Ouch that touched a nervehighlander wrote:I'm not talking to you...lozz wrote:ive seen someone with 19s on one it looks daft![]()
Every time I've found them on an official Peugeot brochure they've just been called "Coupe".gumby6371 wrote:I got my coupe 'starfish' (no idea of the proper name)
Last time I was in derry/london/derry every other car was a mk1 Avensis!FarmerPug wrote: I was in derry/londonderry the other day (you have to see the place every other car is a 406
iwouid avoid using that seller mate,FarmerPug wrote:there was a few avensi around but i think the 406 has taken over the toyota carina as the private taxi drivers car up there the 406 is as common as the skoda superb is in belfast.
about the alloys though them silverstone ones the seller days they will fit the 406 and can be delevered and bought for £250
FarmerPug wrote:99.9% isnt bad but i cant read feedback on the iphone how bad is the negative feedback
