P0230 Code
Re: P0230 Code
I checked that one and gave it a bit of a clean with some electrical contact cleaner. Will try unplugging all the plugs again and gives the pressure regulator another clean before I try an source one.
Re: P0230 Code
Really beginning to lose heart now! I took the pressure regulator out again and tried moving the tip up and down to clean it but it doesn't move??
I went to a scrap yard and picked another one up but when I got home and checked it they were slightly differen?? The sourced one doesn't seem to have a tip on it. The guy in scrap yard said that sometimes the tips seize on them so I took a chance but on closer inspection it doesn't look like it has a tip on it.
I refitted my original one and the car seemed to run for ten minutes then packed up again. I tried fitting the one from scrap yard to see if that worked but no....
- 2.0 Turbo
Re: P0230 Code
well you can get a new one from ebay for £69ish
http://www.ebay.co.uk/itm/PSA-PEUGEOT-A ... 460283f99c
Re: P0230 Code
Thanks Lozz.
I have just read that post and its slightly different to the fault i am having as there pump in the tank is not working where mine is.
I thought a would ask the expert a question but the cheeky buggers want £22 to answer it!!!
Back to free forum trawling me thinks!!!!
Re: P0230 Code
womble171 wrote:Thanks Lozz.
£22
