Replacing dash (D9, fully mux)
rwb
Post by rwb »
I got myself a 5 clock dash :D
Now I just need to swap it over... without upsetting the BSI. (I've finally got a new radiator fan too, but for exactly this reason I'm getting a pro to swap that.)
Presumably I must disconnect the battery.
What else is going to go wrong?
Re: Replacing dash (D9, fully mux)
The mileage might end up incorrect, or the two mileages from each clock being added together, :(
rwb
Post by rwb »
Oh yes: what's the mileage algorithm? I've heard it's either the sum or the maximum of the two. The maximum should be OK because I'm on 192k now and I doubt the donor was on more (although it was very very shabby).
not sure how it works tbh,
My guess is the Bsi trys to correct the mileage, thus adding the cars mileage to that whats stored on the donor clocks,
icouid be wrong tho ,
nutski
Post by nutski »
Normally the BSI and instrument cluster will compare the mileages and then the highest one will replicate to the other.
So is BSI is on 120k and cluster is on 140k then the BSI will update to 140k, if you then decided to put in a cluster with less miles on that would update to 140k too.
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
rwb
Post by rwb »
Is it sufficient to remove only the + terminal (which has a handy clip) or must both terminals be disconnected?
(I discovered that disconnecting the + then discovering that the - is not 10mm and I don't have a small enough spanner, then putting it back rest the date and time and auto lights.) :oops: :oops:
nutski
Post by nutski »
When i remove the BSI and ECU i've got a routine i stick to just incase:
Unlock car, pop bonnet up
Shut the door and leave the car for 3 minutes for the BSI to shutdown
Remove both battery terminals (i hold them together for 10 seconds to drain residual charge)
Then remove ECU/BSI
I had them out a few times and just don't want to risk damaging them
2003 406 2.2 HDi SE
rwb
Post by rwb »
Bought an 8mm spanner.
Followed battery procedure.
Swapped dashes over.
Haven't broken anything :D
However, oil temperature gauge not working :x
I guess either the sensor isn't present (for some reason I was certain it was) or it needs Planet to enable it.
Where is the oil temperature sensor?
rwb
Post by rwb »
So I'm now looking for Planet owners
Today: near Huddersfield
Tomorrow: anywhere on the way from Huddersfield to Basingstoke
:cheesy:
rwb
Post by rwb »
I just saw this in the handbook:
Peugeot wrote:After every reconnection of the battery, switch on the ignition and wait 1 minute before starting to allow the electronic systems to be initialised. If slight difficulties are experienced after this, please contact a PEUGEOT dealer.
but this is all it has to say about disconnecting the battery. Presumably the "slight difficulties" will be fixed (they hope) with a BSI reset. :roll:
V6Exec
Post by V6Exec »
rwb wrote:Tomorrow: anywhere on the way from Huddersfield to Basingstoke
:cheesy:
I am just off the M11 - bit of a detour, but if you don't find anyone else on route ...
406 Coupe S HDi
PP2000 clone interface
V6Exec
Post by V6Exec »
Success eventually - Planet has far too many confusing options.
It seems you need to tell the car that it has both the temp gauge and the sender unit. I suppose it makes sense as you are telling the system there is a multiplex source and sink and they both dont need to exist, but surely the system could have been designed to allow all sources to put data on the bus and all sinks to accept data off the bus without explicitly having to option them.
However a useful option was found today, masked by an obvious mis-translation. There is a way to turn off "economy mode" it seems - show room mode disables "fuel saving mode". A mis-translation perhaps?
406 Coupe S HDi
rwb
Post by rwb »
Big thank you to MrV6 :D :D :D
V6Exec
Post by V6Exec »
Wrong V6 handle there MrV6 is someone else on the coupe club with a very useful website :mrgreen:
Did the gauges all work fine on the trip home?
406 Coupe S HDi
rwb
Post by rwb »
:oops:
Yeah, it works perfectly.
Was most of the way to the M11 before it got up to 90, and it stayed there down the A10 until I got to the dual carriageway and got my foot down and it crept up to 115. Stayed up at 115 cruising at 60 to 65 down the A1. M25 was busy so sat behind a wagon and it meandered down to 90.
Will be interesting to see how warm it gets on the commute into work.
