Hellllp
My fan still not working it was on all the time then it stopped is it the big thing under glove box?
Also could it be a fuse it very confusing under the drivers bit as I can't really see if any fuses are blown or which one it is
Any help much appreciated
Oh and happy new yr all
Thats the cookie behind the glove box, only held in by 3 torx screws and a couple of cables to unclip.
You might see a nicely melted/blackened connector which could be the problem, other than that it's more than likely the resistor which is replaceable.
If you can get hold of a complete working fan replacement from a breakers it's a really easy swap.
2003 2.2 HDI SE
