Fan
teddyboy
Fan
Post by teddyboy »
Hellllp
My fan still not working it was on all the time then it stopped :cry: is it the big thing under glove box?
Also could it be a fuse it very confusing under the drivers bit as I can't really see if any fuses are blown or which one it is
Any help much appreciated
Oh and happy new yr all :)
gumby6371
Re: Fan
Post by gumby6371 »
Thats the cookie behind the glove box, only held in by 3 torx screws and a couple of cables to unclip.
You might see a nicely melted/blackened connector which could be the problem, other than that it's more than likely the resistor which is replaceable.
If you can get hold of a complete working fan replacement from a breakers it's a really easy swap.
2003 2.2 HDI SE
