had alook on the www.but failed
thanks
Cheers, thats the radio idea gone then lol,RobTurbo wrote:A speedo swap, it's far from a straight swap but the actual wiring might be as simple as just plugging in, but I need to check the diagrams first.
You might have problems with the stereo from a multiplexed car, they are coded with the car's vin, if the vin doesn't match you get a beeping through the speakers, it may be possible to just erase the vin from the dump in the stereo on VAN, but IIRC on CAN it won't turn on until it gets a signal from the bsi.
