Note "Configuration F1" button in the bottom left - it's important!
While I was in there I checked the fault codes and the preheater relay one had returned, so I tried actuating it. Yes, I can hear it clicking, what does that prove? I also ended up in a loop at this stage, whatever button I pressed started the test again, so I ended up having to shut everything down and reboot the laptop.
TI noticed a link that said "Check after operation" so I clicked it to see what it was. It said something about "have you done what you are meant to have done?". OKed that and the next screen said:
I also saw some other stuff to play with:
It might be interesting, then again I might wish I hadn't...
I also spotted this:
What, they don't have windscreens in Oz?
And finally, job jobbed, I started clearing up and heading for the first aid box when I noticed the sill lights were on - Que? Oh no, what have I done?
