Indicator tick/tock noise gone?
- maglite
This has happened a few times now. What happens is, on my D9 when I use the signal stalk to signal left or right, there is no "tick/tock" noise. After approx 15 mins of driving it kicks in. Has this happened to anyone else?
- DaiRees
- mjb
Have you used your hazard light button recently?
On the D8 at least the sound is generated by the relay for the lights. If there's no sound the likely cause is either a blown fuse or a dodgy connection on the hazard light button. As I've discovered when driving with half the dashboard off, disconnecting the hazard light button will stop the indicators from working as it's all part of the same circuit. Apparently it's the same situation on most cars...
