Wiper squirties gone crazy!
Morning guys,
I was driving to work this morning and my wiper squirty didnt work, then all of a sudden it was coming out from my right hand headlight (on motorway lol)
When i stopped at work and inspected, the cover on the bumper where the headlamp squirties are was hanging off. It was glued on, so almost like the pressure of it trying to open has caused a problem.
I knew my car had the front headlight washers - but i have never used them - or even knew how? Do they come on automatic when you do the windscreen?
Anyway - now when i go to wash the windscreen, i get a fountain from my headlight! How can i cure this one? dont mind loosing the headlight washers...
Thanks Pete
406 2.2 HDI 2001
Thanks Pete
406 2.2 HDI 2001
406 2.2 HDI executive Estate
Re: Wiper squirties gone crazy!
Mourning
Did you try pulling the headlamp washer fuse? (Fuse 7 full-mux)Windscreen and headlamp wash
Pull the windscreen wiper stalk
towards you.
The windscreen wash then the wind-
screen wipers operate for a fixed
period. The windscreen wash and
headlamp wash operate simultane-
ously for a few seconds,
only if the
dipped beam or main beam head-
lamps are on.
Ah brilliant! that makes sense why it only works sometimes!!
Havent tried pulling the fuse yet. Ill do it tnoight, good idea
Pete
Pete
Morning, the headlight washers activate when you have your headlights on and you use the windscreen washers. This can be deactivated with pp2000 if you have access to it.
In the meantime, remove the three small torx screws from under the bottom of the bumper, drivers side and gently pull down the cover. There should be 2 motors, one nearest you is front windscreen and the other is headlights. Check all pipes for blockages and fitting to see if anything is amiss.
You may get wet at some point......
Thanks gingermagic i will check for blockages - but think i am going to pull the fuse first. cant say i would miss them
If you didn't know, there's a hefty water pump and large(r) hose to the jets in the bumper; the warty pressure makes the jets push out of the bumper (diagonally) and squirt the headlights.
Sadly I think we all concluded long ago that all these things do is squirt and make a mess of your bonnet! they serve no other use, I mean, since when did squirting a bit of cold water on something actually clean it?
I disabled my headlight washers when I fitted a non-exec bumper to replace my fubared one. I had to also change the reservoir, remove the unused hoses, jets and swap motors over...
I only did this as I didn't fancy cutting holes on the bumper for the jets, and I think if the headlight washers are fitted then they check for function on the MOT?
I don't think so - a headlamp cleaning system is a requirement if you have HID's, (as is a working beam levelling system or self levelling suspension).
Bet that never gets overlooked.
What I find a pain is that the headlight washers activate everytime you clean the screen with the lights on which seems a total waste of washer fluid,my BMW headlight washers only activate every 6th time you clean the screen which is far more sensible,even better was my old Manta GTE and my old M535i had actual wipers on the headlamps which really did clean them.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Seems a good idea. Does it come as standard?
Which,the 6th wash or the wipers?
I meant the 6th wash gubbins.
Did you edit your post to add the GTE / 535 wipers bit, or am I really going barmy?
Your going barmy Eric.................................,no I did edit it,yes it's standard on the BM.
