pp2000
- 1.8 8v
Re: pp2000
well took the plung and brought pp200 install on to a laptop running xp
cant get the right code
got a key gen
anyone want to have a go for me
got a key gen
Re: pp2000
Hi mate - it takes a couple of goes to head round it. If you still can't figure it in a few attempts then check the 'read me' files as there should be a step by step guide with pictures.
Also, there is a walk through on youtube.....
- 1.8 8v
Re: pp2000
done it once took a lot of time
connected t to the car etc then says it needs activating again
Re: pp2000
Yes I did that too, but that is because I updated the software from the CD and I had to do it all over again...
Don't give up, my laptop has just gone 'band' so I need to sort mine out too - if only I can remember how
Re: pp2000
once it's up and running don't let it connect to the net to update as it need reinstalling, mine tries to update every time i connect mine to the car.
- 1.8 8v
Re: pp2000
turned the wireless of on the laptop so it didnt connect to net
running version 22.12
going have another go now see how far i get lol
if i cant got a good i.t bloke who will have a o for me
Before it goes out the window
Re: pp2000
I think you need to plug into the net to activate but not on a search engine or anything - I think it just needs to see a connection to activate - or is that just my one..?
Upon start-up mine says 'check for updates? ' then definitely say no as if you say yes it somehow forgets and needs re-bloody-activating........
Look at the 'read me' files and study the pictures. Its what made me install it and not launch it across the room....
- 1.8 8v
Re: pp2000
launch across room was ment as joke
done a complete reinstall AGAIN
server request code is now at 276**
think last time i was on 28 summit
will carry on should be fun lol
Re: pp2000
you don't need to be connected to the net ,when you get to the section "activation" it gives you 2 options one is automatic via internet or manual, manual is the one you want.
- 1.8 8v
Re: pp2000
Spent three hours last night useing key gen still no luck
start gain now
start gain now
Re: pp2000
It's a pain but can be done, discovering you can copy/paste the keygen output code makes it a bit less irritating.
Last time I was a this stage, my problem was in not putting the right account and computer no.s in to begin with......
Luck
Luck
- oldskoolskool
Re: pp2000
I couldn't get on with the disc supplied with mine so downloaded pp2000 and keygen from here
http://www.mrv6.co.uk/software/Diagnostic_software/
2003 - Aegean Blue - 2.2L HDi - S
Nicowico pipes, de-fapped, de-egr, K&N, pipecraft stainless exhaust, Re-map, paddle clutch & SMF, Nakamichi cd400, 5000k hid's & led's
Styled by piniferina, modified with shopping trolleys and car doors.
- 1.8 8v
Re: pp2000
Cheers will save that file sorted it all now took a bit todo but all done car sorted as well
- 1.8 8v
Re: pp2000
Just to thoughs that read this
While i had the pp2000 connected to the car to reset the anti pollution failure which was presure failure on the diesel rail
reset all done found out that the pp2000 can not find the additive ecu did this a few times
Have jacked back of car up and cannot find the additive tank
Ths car has been in the family for over 7yrs (dad) previous to me and neither of us new
So a bonus to me then
