Another starting trouble thread
dave406
Post by dave406 »
Ok so typical post about cold starting been fine all summer now its getting cold it takes an ages to start
Had a free battery check done 95% health and the alternator is putting out 14+V. Ones its been started for the day its fine. It takes a good 10 seconds to start and sometimes it will 'catch' and if you release the key it stalls so you have to hold the key for a split second more. Another this the first 1-2 secods it sound like its miss firing.
Glow plugs? injectors?
(02) 406 2.0 HDi GTX Estate AUTO AC+SN in Delft Blue aka Rhodes Blue
Re: Another starting trouble thread
Been thinking about this, the possibilities include:
Lack of fuel, (lift pump or injectors)
Lack of compression, (low cranking speed or engine wear)
Intermittent operation of crank or cam sensors.
Glow plugs might affect it a bit, but if you can normally fire it up before they've had a chance to do anything, you don't need them.
It does sound similar to Captain Jack's recent injector problem, therefore I recommend:
Check the lift pump works every time.
If you can get it diagnosed cheaply, do that next.
Do a leak-off test.
Chris, feel free to make use of my PP2000. Yes, do a leak of test first - I can help with that if you want as well.
dave406
Post by dave406 »
Caption Jack that would smashing when would be best for you?
Chris, today is fine if you can get over to me.
dave406
Post by dave406 »
turns out sam,e issue as ///cj's old 406
Fingers crossed a new injector is all you need
dave406
Post by dave406 »
We're DoD you get,the washers.from Alex
dave406
Post by dave406 »
Injectors and seals ordered ow we wait
dave406
Post by dave406 »
Fingers crossed its fixed :supafrisk:
406owner2
Post by 406owner2 »
I take it from your last reply the problem has gone away ?
I also have a starting problem on my 406 1996 petrol, but only in the mornings when it's cold, however my car is petrol not diesel, could the same apply for me ?
dave406
Post by dave406 »
Mine was an injector
406owner2 wrote:I take it from your last reply the problem has gone away ?
I'm reading that as a yes, can you get your injectors tested/cleaned where you are (without sacrificing a kidney that is...)
ZilogJones
Post by ZilogJones »
I've been having the same trouble with cold starts since I got my 406. I've already wasted money on glow plugs, getting the starter motor reconditioned, then I forget for 9 months until it's winter again :)
Will a PP2000 be able to give me any useful hints towards injectors if one of them is dodge? Or should I do a leakoff test? And did you get them reconditioned or replaced? How much did it set you back?
I've got a Siemens HDi, so no lift pump, right?
2002 2.0 HDi 90 Rapier saloon (for sale)
dave406
Post by dave406 »
Mines still having. Trouble
