Peugeot 406 HDI Familial electricity problem
mulhamaryan
Post by mulhamaryan »
hy
i have a Peugeot 406 HDI familial
the problem is the reset of all electrical parameters when i turned it off the car and back it on all the old parameters like
radio, time,kilometer counter back to default or last saved parameters when i've brought the car
example
if the radio's station was set on 92.2 FM and saved and turn off the car and back on the radio will auto back to 89.9 FM
and same problem with kilometer counter is always on 65 Km when i turn on the car
and the air condition always on level 2 when i turn on the car
Briefly just i want to say that all electrical parameters on the car when i turned it on it's always back to last saved parameters
so please can some just tell from this problem is coming
Re: Peugeot 406 HDI Familial electricity problem
Hi..
iguess its a BSI related fault.
any other issues?
has the drivers footwell carpet ever got damp?.
I seem to recall, in the dim and distant past, someone having a similar problem and it turned out to be a fuse. Might not even have been a 406 but I guess it's worth a look.
The permanent live to the radio would be worth eliminating.
What year is the car?
mulhamaryan
@lozz what should i do in this case ?
@steve_earwig i didn't understand what you mean
@Doggy the model year's 2003
^ im not sure tbh,
i'might be wrong but as far as im aware,the Radio is all paired up with the BCU and its the BCU that holds all the Memmory for it as well as the mileage etc.
so id go with what doggy as mentioned.
mulhamaryan wrote:@steve_earwig i didn't understand what you mean
You're in Mauritania? Fusibiles?
Peut-etre F ici:
mulhamaryan
@steve_earwig yes i'm in Mauritania
good one but where can i found it know because i have no idea about electrics things
and the reason why i don't want to take it to an electrician because we don't have a good one here !
and please if you can speak in French that will be better :)
mulhamaryan wrote:and please if you can speak in French that will be better
Eeee! Fechez la vache! J'ai étudié le français à l'école, mais c'était avant que 40 années :supafrisk:
mulhamaryan
ooh finalement ce mieux en tous cas en francais :p
ce bien claire maintenant mais une tout petite question c'est quoi le service esp/asr grâce que a chaque fois que je demmare la voiture il me dit que le service esp/asr hors service et même anomalie aire bag pour l'air bag c compris
mulhamaryan, just a suggestion, you may find it easier to also try the french 406 owners club: http://www.passion-406.com/
You are very welcome here, but they would be able to converse in french with you more easily than we can.
Bon chance!
mulhamaryan
Doggy wrote:mulhamaryan, just a suggestion, you may find it easier to also try the french 406 owners club: http://www.passion-406.com/
Bon chance!
i think that to thank you i will see it there :)
