Sagwala wrote:Is it because I am using Windows 7. Would be grateful if someone would hold my hand through the process
regards,
Trevor
Don't know for certain, but I suspect so. Galletto is almost certainly an old DOS program, so will work with Windows versions up to and including XP. I suspect there's some sort of 'virtual machine' utility you can use but have no personal experience, sorry.
For XP and the like, simply copy everything off the CD to a new folder and create a desktop shortcut to point to the only .exe file
I keep an ancient XP laptop just for Galletto & PP2k
Morning, Thanks for that, really appreciated. I spoke to HDi tuning yesterday and they explained that the Galletto 1260 was very problematic and that a MPPS FLASH CABLE was a much better option.
So I have bought one to try. I will give that a whirl when it arrives and if no joy then I will 'Corby bound' and will make the necessary arrangements with you.
Hi Trevor, I never really trusted my Galletto as it was always freezing/crashing etc..
Where did you get the MPPS FLASH CABLE from?
Kelv.
2003 2.2hdi estate - mine 1998 Volvo 940 auto estate - also mine 2019 Citroen C3 something - the wife's PP2000 user, can help with faults / diagnostics in the Bournemouth area.
I re-installed my Galletto yesterday, on my old PP2000/ diagnostics XP laptop. I'll try to flash my ECU with a different map ( 200 down to the 180 ) as a practice run for the proper remap, when its all sorted.
