Those are the correct tools, yes.
The intake manifold was left in-situ as it's basically an engine-out job to remove it. The elbow is simply removed (two bolts) and the cleaner is sprayed into there, mine was quite expensive to do as so much cleaning fluid was required (very heavy deposits). The chaps spent a good 3 hours solid on it, but afterwards the intake manifold was left like new! It also cleans in the cylinder head itself and around the valves which is often ignored.
The ECU does not allow for smoke, assuming the entire intake/exhaust system is sealed, which after 15 years often is not. Smoke is produced typically when there is a boost leak, this is because the ECU opens the wastegate when the turbocharger is producing the regulated pressure (2000mbar absolute), however when there is a leak the turbo will simply spool faster to produce the same boost. This means the MAF sensor will read the same value it would without a leak, but the ECU has no way of knowing there is air leaving the system so it presumes the engine is using it all and responds by adding the normal amount of fuel. This knocks the stoichiometry off and the AFR becomes rich, meaning high EGT's and black smoke. There are several common locations for boost leaks on these:
- Intercooler (look for oil deposits on the bottom)
- Plastic turbocharger outlet pipe on the back of the engine
- Loose hose clamps allowing air to pass by
Once you're sure you have a fully sealed inlet system, and still have smoke, move onto the exhaust. A leaking EGR valve (which I had) allows exhaust gas to pass into the engine bay, meaning the turbocharger does not receive the full air flow and increases spool times (smoke coming on boost) and if bad enough will prevent the engine building correct boost levels. Removing the EGR system altogether and replacing the heat exchanger with the straight through pipe (see here:
viewtopic.php?f=1&t=23556) solved my smoke issue, as well as simplifying the engine bay a great deal.
Hope that helps, if you have any further questions please don't hesitate to ask.
Best Regards
Ben
