Auto dip rear view mirror
muffindell
2.2 16v
Post by muffindell »
I understand the coupe 406 is sometimes fitted with a auto dip rear view mirror. I've seen a few of these go through ebay at a reasonable price. Can they be easily fitted to a normal salon model or is it more involved than that?
My estate's got one of them. It's electrochromatic, i.e. auto-darkening rather than auto-dipping. Never actually looked how it works, just content that it does :cheesy: , but I always assumed it needed a power source. If so this could be taken off the courtesy lights? Should be easy enough.....
Actually coming to think of it perhaps it doesn't need a power source.... could be "solar powered" like an auto darkening welding mask :?
EVIL things! I really don't like 'em - prefer to choose myself when to flick the lever based on more criteria than just the light level.
neildavies
Post by neildavies »
Myself, I think it works brilliant. I think it was fitted to the SE coupe, not the S. To get it working, there's 3 cables, a positive, negative, and the third is from the reverse lights, so it doesn't dim when reversing. You can just make do with the 2 cables (pos & neg) and if it bugs you when reversing, there's a switch on the mirror itself.
2007 307cc Sport 2.0 HDi 136
muffindell
2.2 16v
Auto dipping mirror
So, does this mean it would in effect (bar a little wiring to the interior light) be a direct replacement to the standard manual dip mirror? If it is I will have a look on e-bay to see if any are going through at a reasonable price.
neildavies
All I know is someone did it to a coupe, so the windscreen must have been the same.
muffindell
2.2 16v
Auto dipping mirror, which wire does what?
Well I am the proud owner of a auto dipping mirror! All I need to know which colour wire does what to enable the wire up, so guys - any ideas?
neildavies
I can find out later, if nobody else does in the meantime. What colour cables have you got?
muffindell
2.2 16v
auto dip mirror cable colours
Hi guys, I now have chance to fit the mirror, but no one really answered my question to which cable does what. There are three wires - white, black and grey leading to the mirrior. I've had a poke around in the headlining and cant find a pre wired loom (LX saloon Hdi on a X 2000 plate). All I need to know which is positive and which is negative, there must be someone with a later (post 2002) haynes manuel with details of this?????
muffindell
2.2 16v
Please help :o(
Someone must have a wiring diagram for one of these mirriors in a later haynes manual or coupe, I don't want to start trying out various connections in case I bugger the mirror.
Mat
Benner
Post by Benner »
Your best bet is to stick a multimeter on it.
No chance for error then.
muffindell
2.2 16v
Auto dip
I don't think a multi meter will help, I'm adapting something that isn't wired for my model 406. I need to know what wire would do what if it were originally wired in.
Benner
Post by Benner »
Ah, so you are wanting to know which is positive etc on the mirror not what is on the supply then.
Someone must know?!
muffindell
2.2 16v
Auto dip
Benner, you are so right! I can't believe that no one on this forum can't help me, I'm getting sooooo fed up not being able instal it :o(
Benner
Post by Benner »
Welton has a D9 and may have a Haynes, so he may he able to help you there.
I've only got one for a D8.
Edit: Just thought, think his is a '99 so maybe not.
