Slightly O/T but my daughter has the above car, its recently become a intermittent poor starter, I think there is a small air leak and the fuel runs back to the tank over night, I want to fit a NRV as I don't think the one in the priming bulb works, my question is does any one know the internal and external bore of the hard plastic fuel lines used in the later pug's.
Tia Alan
2008 207hdi110
Re: 2008 207hdi110
Don't know anything about this particular car, but on 406's without lift pumps the culprit is usually a tiny leak at the filter. Not enough to leak diesel but enough to let it drain back to the tank. Try reseating the fuel filter lid or changing the filter if that gets you a new seal.
Re: 2008 207hdi110
The filter is a sealed unit, I fitted a new one just for the reason that you say, the priming bulb is quite hard and difficult to use (in a v awkward position) so my intention was to fit a NRV and a new priming bulb in a more accessible position, possibly with some clear pipe as on my 406 but its knowing the pipe size to make a good air/diesel tight fit.
Re: 2008 207hdi110
Is it the 1.6 or 2.0?
Re: 2008 207hdi110
Hi Ollie its the 1.6
