BSI- 2 faults
[intermittent] [84C4] Battery charge
[intermittent] [8492] No communication with multifunction display (have fixed this today though)
Engine - 3 faults
[permanent] [0571] brake switch signal: Communications fault (don't understand this one - I know the brake light all function but suspect it isn't referring to that)
[intermittent] [1537] Accelerator pedal jammed (V84->): Strategy active (don't understand this one either....
[intermittent] [1112] Fuel high pressure monitoring: Lack of pressure (leak) (this one has me worried - should i be? How do you remedy this??)
Gearbox
6 fault(s)
[intermittent] [0002] clutch slip - not characterised
[intermittent] [0006] Pressure regulation - Variation / RECOMMENDATION -not characterised
[intermittent] [0026] Throttle Potentiometer - not characterised
[intermittent] [0032] automatic gearbox communication fault with the engine management - not characterised
[intermittent] [0063] Multifunction switch signal fault - intermediate position - not characterised
[intermittent] [0091] Gearbox input speed signal - no signal
Chap who ran the test said, overall, things looked reasonably healthy. I am, optimistically, wishing to believe him but, to be honest, am unable to interpret the meaning of most of these faults, especially the gearbox ones.
Are there any diagnostic gurus out there who can translate the above findings into layman's terms and help put my mind at rest a little? Would really appreciate any feedback.
Many thanks.
