Was just surfing ebay when I saw a fix for the D9 airbag light problem.
If your airbag light comes on the dash for no reason, and wont go out try the following;
Aparently under the drivers/ passengers seat is a plug for the airbag and moving the seat back and forth makes the plug lose. Try pushing the plug/s together and the light should go out, (common fault) dont know if 1 plug does both bags but locate it move it about if the light goes out there is your problem.
If the light dont go out, then its probably your airbag, who knows!
I think most of us knew that, and prob had the same problem.
Vehicles I own:-
Welton wrote:
Imagine how many poor sods book into the dealers just for them to do a bit of 'fiddling' for 2 minutes then charge you an hours diagnostic/labour
well we have to make money somehow Welly
toot, what usually happens on the blingo is the heater matrix leaks and runs down the carpet and shorts out the connector under the passanger seat, this is what happend to my dads one, though im sure the light will flash if its the seat belt pretensioners on a shitroen
Peugeot wrote:what are you worried about? we made car that lasted 10 years"..."Zat is very goode non?
Fixed it Once i had draged all the crap she had under the drivers seat i just messed about with the wires and the light went out.
All i got was thanks, not even a golden nugget graced my palms
