Water and Oil Temp
pauloharpo
Water and Oil Temp
Post by pauloharpo »
Hi all - just completed my 1st 1000 miles in new 3.0 v6 1999 estate - 500 or so pulling a caravan. performance is stunning - my last car was a v6 audi but this is better. Anyway my heart was in my mouth the other day when the oil temp guage went right up when putting ign ition on after a run - it went right to end of guage, then back to normal - i assume this is normal? Also, especially when pulling the caravan the watewr and oil temp do go quite high - avove 90, then go lower presumably when the fan comes on. Is this normal?
I will do oil change and filters at weekend - ant ideas on oil and filters to use?
Much appreciated,
Paul (a Peugeot convert!) :cheesy:
I know I believe in nothing but it is my nothing
jameslxdt
Post by jameslxdt »
as you are towing the temps will get very high, i would recommend a genuine purflux oil filter and 0W40 fully synthetic oil, either mobil 1 or castrol edge as these both work very well at extrmeley high temps, you could also try castrol (not sure of the name) 10W60, its designed to work at even higher temperatures
the reason your oil temp gauge shoots up when you turn the ignition on is becuase its showing you the oil level, but its very innacurate and you shouldnt trust it,
if you intend to use the car for towing all the time i would recommend a hot climate thermostat and a slighty more watery coolant mix i.e. 30% antifreeze
pauloharpo
jameslxdt wrote:as you are towing the temps will get very high, i would recommend a genuine purflux oil filter and 0W40 fully synthetic oil, either mobil 1 or castrol edge as these both work very well at extrmeley high temps, you could also try castrol (not sure of the name) 10W60, its designed to work at even higher temperatures
Thanks very much James.- is Purflux a peogeot item? if not where do i get one? euro carparts?
jameslxdt
Post by jameslxdt »
purflux is genuine peugeot, you can get them from pug, but also euro car parts, you will get a purflux filter just without the peugeot label on it
DH1972
Post by DH1972 »
Are you sure it's not the oil pressure gauge? I've the same car (but a 98) and there's no oil temp gauge...
pauloharpo
DH1972 wrote:Are you sure it's not the oil pressure gauge? I've the same car (but a 98) and there's no oil temp gauge...
I think its temp as it doesn't fluctuate with revs and has 50 / 90 / 120 figures on it or something like that :D
jameslxdt
Post by jameslxdt »
its definatley oil temp as i have the same instrument panel in my 406
pauloharpo
Could i get away with a 0w30 fully synthetic as i have some of that already?
Paul
jameslxdt
Post by jameslxdt »
what make oil is it?
pauloharpo
jameslxdt wrote:what make oil is it?
Pardon my Frech - it is Fuchs!
