Trip computer
lambo
Trip computer
Post by lambo »
Hey up all :cheesy:
For those who dont know,iv got a 98 D8 glx v6
I am looking to get a trip computer up and ruinning and was just wondering how you guys would recomend going about it?
Did they come on D8's as standard in some models?
If so what will i need to do to get the little blighter working?
Thanking you in advance 8)
Andy
mjb from here did it.. there's an old topic knocking around here somere. Search for it and you shall find!
BOOTNECK
Post by BOOTNECK »
If it's the same as the Coupe,just swap the wiper stalk for one with the button on the end and then cahnge the number dial on your radio display to 2,hey presto job done :cheesy:
If the connector going into the back of the display has 2 rows of pins (the connector on the loom, not the socket) then try what Bootneck says.
Otherwise you need to wire in (from memory) a ground, a button, a tap from the speed sensor, a tap on the fuel gauge sender and one line coming from the ECU which I can't tell you about unless your ECU is a Bosch 3.2
lambo
Post by lambo »
Thanking you all for a speedy responce :cheesy:
I shall root around and let you know what i find,thanks again 8)
Eric
Post by Eric »
lambo wrote:Thanking you all for a speedy responce :cheesy:
Hmmm... Might be tempted to try that with my 99 D9 GLX myself.
Would be nice to have the trip computer.
Can't be dealing with wiring and stuff just replacing the stalk.
Things go pop if I touch wiring ;)
BOOTNECK wrote: then change the number dial on your radio display to 2, hey presto job done :cheesy:
It's a D8 thing Welly, go back to sleep..... :cheesy:
DaiRees wrote:It's a D8 thing Welly, go back to sleep..... :cheesy:
What, like everyone else round here :P
jameslxdt
Post by jameslxdt »
if you remove the multifunction display there is a mode switch on the side, to change its function
