Think i need a new clutch, what should i be paying??
ed209
Post by ed209 »
Symptom: High biting point (high pedal) but strangly no slip, even when pulling off in a high gear :o
Result: Abismal clutch control and unsmooth down changes :oops:
Question: Clutch worn out, or is there any adjustments that could made? :roll:
Car: X plate 2.0 petrol (62000 miles!)
Knowing my luck at the moment, if I fell into a bucket of tits; i'd come out sucking my thumb!
How much should a replacement clutch fitted by a general garage cost me?
I call her Starbug 1, because she's green with intergalactic milage!! I do love my D8 diesel.
ed209
Re: Think i need a new clutch, what should i be paying??
Post by ed209 »
I have had it looked at by my local garage today who gave me the bad news!.....................its gonna hurt!
Apparently being hydraulic, its more expensive as more new parts are required, he even talked about a dual mass flywheel (about £230 alone!!). So all in all I am looking at £600+. :cry: :cry: :cry:
I am starting to go off Peugeots!
Anyone else had a hydraulic clutch changed to the tune of £600!
You sure it doesn't just need bleeding or summat? 62K ain't much for a clutch to last, I'm sure there are stories on here of 200K clutches. Unless it's actually the DMF that's knackered?
ed209
Post by ed209 »
I asked the mechanic if it could need bleeding, and he thought that its unlikely!? :roll: He did say that the cluch bites well, and doesn't slip, and the height of the pedal is just down to wear!
A bit confusing though is why when the reg number is put into the parts database, it comes back as a cabled clutch, but its hydraulic!!! :!:
I just think that this car is going to (as we say in Cornwall) bring rags to me ass, and small pasties for tea! :P
ed209 wrote:Symptom: High biting point (high pedal) but strangly no slip, even when pulling off in a high gear :o
Answer: They're all like that. End of.
ed209
Post by ed209 »
Are they?? :shock:
jameslxdt
Post by jameslxdt »
yep, typical 406 thing, after i did my clutch the bite got even higher :lol:
mbell666
Post by mbell666 »
I've had new clutch and DMF on my HDI (at 148k). the bit is still at the very top of the peddle.
I wouldn't touch the clutch till it starts slipping (i could make mine slip at 60mph in 5th gear only). but could here the knock and squeek of the gone DMF. Didn't realise the petrols had dmf, though they had solid fhywheels.
1997 Honda Prelude 2.2 VTi
ed209
Post by ed209 »
Thats really shocking! Do you get used to driving it in the end? At the moment im pulling away like a learner due to the lack of "feel" to the clutch! They should have put it on a switch, clutch on, clutch off!! :P
ed209
Post by ed209 »
mbell666 wrote:I've had new clutch and DMF on my HDI (at 148k). the bit is still at the very top of the peddle.
I hope there is no DMF, at £230, I wouldn't want one either!
Why are cars soooo over-engineered these days? I can understand it to a degree, but for the general run around hack, I'd opt for simplicity! :P
V6Exec
Post by V6Exec »
Can't say I have had any problems with the clutch bite point on my D8 or D9.
Have driven a range of vehicles so that may help - try an old Ford Cargo and you will appreciate any clutch :mrgreen:
406 Coupe S HDi
PP2000 clone interface
mbell666
Post by mbell666 »
You do get used to driving it, its fine once you have been driving the car a while.
The HDi is not very good of the starting blocks and the clutch doesn't help it getting it away quick.
I really hate the down-changes whilst slowing down in my HDi, at first you have the high bite and poor feel of the clutch then the revs have dropped like a stone, then you have to smoothly overcome the high resistance of the Diesel engine and make it all work togther :frown:
I have tried heel and towing which is a bit gay in a Diesel (but kind of works if you can be bothered) and I regularly 'blip' the throttle before a down change (if I'm not busy braking at the time).
I nice petrol engine which holds it's revs a bit longer makes for much more agreeable down changes, and a V6 petrol are even better here.
Actually then at the risk of highjacking this guy's thread........How do you drive yours?
Have to agree with V6exec on the old cargo clutches :shock: think i been very lucky
with the clutch on my hdi ,it bites quite low and in general the gear channges are
quite smooth apart from a bit of notchiness from third now and again :) :)
My clutch is luxury (compared to the cable clutch on my old D8) :roll:
