Trying to get my remote fob/plip locking working!
Have got a two button plip (RF type I believe) remote/fob on my '96 406 that doesn't work and hasn''t as long as I've had the car though the fob needed new batteries. I only have the one (primary) fob and purchased some new batteries for it in the hope of getting it working. Replaced the batteries and followed the procedure for re-programming the remote (pressing big button three times while key is in the swtiched on ignition) and still not working. Where do I go from here in regard to repairing it/getting it working again. I know of a 406 that has working remotes and its the same year as mine.....would I be able to swap the remote fob system over?
1996 Peugeot 406 Executive 1.9 XUDT
- Site Admin & Mad Biker!
Re: Trying to get my remote fob/plip locking working!
Does the LED light when you press the button?
Yep, LED lights up.
Hmmm. It can't be the original key or the transponder has gone faulty in the car; you can't reprogram a second hand key to the car but there is a thread on the transponder which is fairly recent. A new key is about £120
So it's obviously a key or receiver fault. How do I get to the receiver just to make sure it is seated correctly? Also I didn't think the immobiliser keypad type early 406 had transponder keys.
Yes you're right, no transponder on the D8!
I meant receiver!
Just to confirm then, I cannot take the receiver and fobs from a working '96 D8 and fit them in my car without main dealer programming?
Anyone got any experience of any of this???
Doesn't look like it. I can't see why it wouldn't work, it's not like it's got a BSI to appease or anything.
Can anyone else see why a Immobilser Keypad type 1996 406 RF Receiver and Fob that works wouldn't be able to be transplanted into a same year 406 with non-working remote locking without needing to be reprogrammed by the main dealer?
- jameslxdt
yes, you need the C/L ecu from behind the glovebox and matching keyssidmon1 wrote:Just to confirm then, I cannot take the receiver and fobs from a working '96 D8 and fit them in my car without main dealer programming?
When you mean matching keys, do you mean matching fob bodies?
- jameslxdt
yes
- jameslxdt
if you open up the key there will be a tiny sticker inside with a number, the one that starts P (primary) should have a corresponding number on the C/L ecu
So I only need the fob part of the key, not the blade as well (i.e. I can replace just the fob part on my key). How do I remove the glovebox to get to the central locking ECU, and how do I remove the ECU itself?
