I can’t seem to overwrite the settings in the seat memory on my 1.9TD exec
It will move to setting 1 or 2, but I cannot change either of those settings from how the previous owner had it. I have tried doing what the manual says pressing the M button and the number I want to change alternately until I hear the beep, but I never get a beep
Any ideas where I should be looking for a problem?
Ritchie wrote:I have tried doing what the manual says pressing the M button and the number I want to change alternately until I hear the beep, but I never get a beep
I haven't changed the settings on mine for 6 years, and I cant be arsed to go and check the book so please excuse me if I'm talking shyte, but I thought the procedure was to hold to hold down "M" and then press and hold "1" or "2" (while still holding "M") until it beeps? Give that a try.
The procedure is: move seat and mirrors THEN press and hold M and 1 (or 2) together until it beeps.
To recall a position open door and BEFORE you put the keys in the ignition press briefly which number you want. If you have the ignition on then you have to press AND hold the number button until the seat and mirrors complete there movements in full (a brief press here will just sort the mirrors only).
