I fitted Venetian Blinds to my front windows, this way I can vary the amount of transmitted light into my car (not out from) from 100% to 0% My interior is illuminated with 6x500w Halogen floods so when I close the blinds my light transmittance (out from, not into) my interior elements is controlled so I tell the others to "F" off too
I saved all my roses choccie wrappers to do mine with,wonder
where i would stand legally
Oh and i just partially closed the front window blinds and the room darkened,
does anyone have an explanation for this as light is only transmitted out
not in
When you shut teh blinds the light from outside went next door to illuminate their uptairs bedroom, if you open them again it should come back but I haven't tried this myself.
Hope this helps.
I've just turned the lights off in my little office and stubbed my toe on the desk when I turned the lights off (4x double flourescents 5' long) where did the light go? I thought it went behind the photocopier but when I looked it wasn't there
The legal position is that the front side windows on all cars must allow 70% of light to pass through them. That figure also applies to the windscreens of cars first used before April 1985; any car first used from then onwards has to let 75% of light through the windscreen.
To bring that into perspective, most cars these days are supplied with tinted glass fitted as standard, generally between 15 and 25% tinted, so virtually any aftermarket tint fitted to the windscreen or front side windows will render that car illegal which might result in a prosecution and a fine of up to £2000.
