A little project
A little project
Since I cannot easily replace the rear speakers in my saloon, and after trying fruitlessly to fit standard 6x9's without shaking the shelf to bits, I decided to build a custom rear shelf. This will be made out of 18mm MDF and will fit it out with Diamond 6.5" woofers. Here's the preliminary work, which is simply a cut out of the shelf (it fits :cheesy:). My carpentry skills are completely crap, so don't laugh....
I got a donor rear shelf from scrappers to build mine upon, since I would need to hack up the original shelf to fill the tricky gaps at the back and cover the front of the shelf where the seat belts go through.
Haven't figured out how to fix the shelf to the body of the car but will probably lay it on some blocks of wood and attach it to the metal shelf.
Not quite sure on the finishing bit, but will probably cover the whole lot in some foam wrap cushioning and finish it off with black vynil.
Just need to find my lost speaker rings... :?
Any tips/advice/abuse/etc..?
Re: A little project
WTF?
He's making a sound shelf, much better for handling louder speakers without that chavtastic farting noise you hear coming from spotty youth's 1.0 novas.
I've only ever made them for hachbacks so I can't add much, although I reckon you'll need to trial fit it about 12 times...
Sorry, it's just that all I saw was a wardrobe door and a sawn-off parcel shelf :?
Wardrobe door? You must have some interesting decor in your gaff :shock:
steve_earwig wrote:Wardrobe door? You must have some interesting decor in your gaff :shock:
Speaking of gaff's, Cap'n appears to have a Juliet Style balcony about his apartment overlooking a nice wooded area to the rear aspect (laid mainly to lawn) 8)
That balcony is my "garage"!
Looks pretty good to me CJ! You definitely won't get any shelf vibes!
Trimmed it a little so that the edges are smoother. Went out with my pieces and it all fits pretty snuggly! Ordered 9 metres of 4mm foam wrapping for 5 quid(!) and some speaker rings. Just need to figure out what to finish it with but I think I'll go for the black vynil.
Can anyone recomment some nice adhesive to hold to foam + vynil to the board without letting go in a few days?
Need to figure out how to fix it to the metal shelf as well, but I think I'll use some blocks of wood to attach it all together.
Spray adhesive (carpet spray glue)?
Captain Jack wrote:Can anyone recomment some nice adhesive to hold to foam + vynil to the board without letting go in a few days?
Spray contact adhesive :)
An update...
Cut out the holes for speakers and attach the spacers
Attach the end bits of the shelf and cover exposed MDF with foam cover
Second layer...
And the back
Just need to cover with vynil and that's it.
Good job CJ! 8)
Nearly done....
Sorry for the crap quality pics...
Just need to fit it... once it stops bloody raining
It's in!
There's still rattle coming from somewhere if I turn the volume up REALLY loud, but I think it's the seat belt spools. I Dynamatted the metal shelf underneath so it could be that too. Going to stick some wadding in there to "damp" vibrations and it should be good :)
