as above i can put the drivers side window down with 1 touch but ive got to hold the button to put the pass side 1 down till all i want to know is there a way to reprogramme them so that they will work by just touching them the once
cheers
ian
Electric windows
Re: Electric windows
Rob the relays out of a VW?
- Site Admin & Mad Biker!
It's by design. The drivers window switch has a double click, the others don't. (This is for a D8, don't know about D9!)
D9's the same. I'm sure on other cars (eg veedubs) it's done on how long you hold the button down and I always thought it'd be an idea to see if the relays would do the deal. It's on the list there, see it? Just above having my toenails manicured.
D9 is the same, coupes all have one-touch on both sides thoughteamster1975 wrote:It's by design. The drivers window switch has a double click, the others don't. (This is for a D8, don't know about D9!)
If you need to reset it, lower the window to the bottom then hold the switch down for about 5 secs, then raise the window and hold the switch down for about 5 secs, and the one-touch should work again
