Which gearbox do I have???
LeeB
Post by LeeB »
I have a 2002 406 2.0HDi Rapier saloon, with a 5 speed manual gearbox. Unfortunately, the ABS rings are shot and the cheapest (and easiest) option I've found is to replace the front driveshafts - around £190 fitted for recons.
Problem is - there are two types of driveshaft - depending on which gearbox I have.
Can anyone tell me where to look for a "type plate" or similar?
Thanks in advance,
Lee.
Re: Which gearbox do I have???
ML5T or ML5C? I *think* that's down to 90bhp or 110bhp but the easiest way is if you post or pm me your vin.
5 speed huh? :mrgreen:
...Or TURBO DIESEL DW10TD AND GEARBOX BE4R
I think 90's have the above & 110 / 136's the ML5T or ML5C
I'm basing this on the different final drive ratios - Welly's 110 had the same o/a gearing as mine.
- think early BE series have rod-type gear selection linkage, later BE4 & ML5T have cable operation (2 cables) and ML5C have 3-cable set, with lifty-up knob to select reverse - my 136 has this arrangement, buy at least some Y-plate 136's had the older arrangement with reverse back from 5th.
dogslife wrote:..Or TURBO DIESEL DW10TD AND GEARBOX BE4R
Gah! I thought there was a difference but I didn't see it and concluded I was remembering D8 1.9/2.1 :oops:
Btw does anyone see a problem in posting VINs? It's not like it's your credit card number...
Example below
(or is it a case of all the crims need now is the number plate?)
TopDonkey
Post by TopDonkey »
most VINs are visible through the windscreen nowdays anyway, so its not like they are hidden, so i dont see any problems with posting VINs and/or reg numbers, you can read them off any car in the street
Good point, I was thinking we'd make things even easier but all the modern crim needs to do is march down the local supermarket with a notepad anyway.
