Happened while turning a corner, so I'm thinking steering wheel / comm2000 etc.
I tried turning it off later, removing ign. key / re-starting, but got the error straight away.
Now I've fixed dodgy connections under the seat on my previous Cistern and clearly this could be the same, but I just wondered if anyone else had had the same joyous experience with a multiplexed D9?
That's a new one on me sounds like something to do with the steering wheel area really. The under-seat wires just tend to bring up a quiet little light on the dash
Has yours got traction control? if so there's normally a steering angle sensor communicating with the ECU, throttle, ABS etc - don't know where the Air Bag comes into this but it is French
Might pay you to gingerly remove the steering wheel for a looksee?
Otherwise this might be one of those faults that fixes itself
Wouldn't he get an ESP warning (bong!)? Fiddle with those connectors under the seat, they seem to be the most common fault. My D8's AIRBAG light started flashing when I had it on full lock, I was certain that was going to to be the steering wheel clock spring thing but I had Pug test it anyway and it was the ECU...
Done a few more runs since then and it's consistent....bong!AIRBAG FAULT about 15 seconds after starting the engine.
I'll check all the connections under the seats as soon as poss.
One saving grace, at least after the inital warning, all I've got is a static 'AIR BAG' warning on the dash, which is a damn sight less prominent that the constant flashing light my Xsara had, or my bro's D8 - (even with a bit of insulating tape stick over it).
Progress?
plus ça change....
Maybe with yours being a bit newer than most they introduced an MFD bong along with the dash light?
Have you got the 'Sausage Head' side airbag light? (I think it's Red?) some (including mine) appeared to be missing this one even though it says 'Side Air Bags' on the seat base itself.
mmm.... busy little spot under here innit.....
just identify & disconnect / reconnect the 'pyrotechnic triggers', (aka detonators)) a few times.....
'allo! Wotz these here shiny cylinders wiv the wires in the top
* finally dawns on dopey here, he's looking at the seat adjustment motors
dogslife wrote:One saving grace, at least after the inital warning, all I've got is a static 'AIR BAG' warning on the dash, which is a damn sight less prominent that the constant flashing light my Xsara had, or my bro's D8 - (even with a bit of insulating tape stick over it).
I put the passenger leather in the other day, and the pre tensioner connector was different - wtf? - and had the air bag light flashing all the time, so whilst fitting the ali dash rings, I was the odd bulb short to light up the dash, so the air bag bulb was donated elsewhere
1999 D8.5 HDi GLX - Sold
2007 Mondingo Zetec - I seek forgiveness Bring back my 406
I can understand you doing that, but you might have problems come MOT time.
If I have to touch mine again, I'll do away with the connectors, as they're the only bit that ever seems to go wrong.
Probably silly of me, as at least with that annoying light going away, i'd have to sort the connection out, whereas now I can procrastinate to my hearts content.
Maybe a job I could of done last night instead of taking off the B pillar decals, but ah, oh well
