Hi just had my instrument pannel die on me, no speedo, tacho, fuel gauge or water temp, and few other warning indications, tracked it to the Instrument control unit. Does any one know where this uniy is located behind the dash, or is it part of the instrument pannel (so the hole instrument pannel needs replacing) :arrow
Pull the instrument cluster out (3 screws to remove the plastic surround - be careful with the vents - then 4 screws on the cluster itself). Either the plugs are dirty/not in properly and just need re-seating, or you'll find a dry solder joint on the pcb behind it which needs re-soldering. The latter is quite common
Yep checked rthe fuses, Its bloody working again now, damne french electrics, but will take the cluster out and go over the soldering again bud, thanks, for the advise
