no heater
- 1.8 8v
no heater
now the wifes heater motor has stoped working so i replaced the resistor pack with a known working one from my 406
and still no blower fan working i then changed the digital control and still no fan working is it comon for the fan motor to fail ?
thanx steve
thanx steve
- plod
Re: no heater
common as muck bud
With mine there is a white connector block behind the glove box that was shorting out - obvious from the scorched markings on the connector.
It blew the 50a fuse which is located in the engine bay fuse box.
I had the connector replaced with some heavy duty connectors and replaced the fuse - no more problems for me
1999 D8.5 HDi GLX - Sold
Bring back my 406
- 1.8 8v
Re: no heater
ive checked the connector and all is fine as is the 50a fuses in the engine bay fuse box so im guessing its the motor as thats the only thing i aint changed
- peugeot406rapier
Re: no heater
my heater blower motor used to rattle and crunch really bad i got a second hand one from a fella breaking a 406 for £20 just 1 plug and 3 torx screws and it was off its really simple
Martin
Martin
- 1.8 8v
Re: no heater
ordered 1 of ebay 18 quid delivered from an 01 plate car
just waiting for it to come now
- puggy
- Resident Pervert
Re: no heater
If that dont work try looking at the ignition switch cos thats what
it was on mine
it was on mine
- 1.8 8v
Re: no heater
puggy wrote:If that dont work try looking at the ignition switch cos thats what
it was on mine
right guys after more tinkering ive removed the old motor and tested it
ive now check for + v to the motor when its switched on but its showing no voltage
refering to the ignition switch what part of the switch was defective on your car ?
could you be a bit more precise as to what needed looking at pics even ?
thanx steve
- 1.8 8v
Re: no heater
right then guys the heater is now fixed
was just a case of following the grey wire from the ignition switch to the connector on the motor cut said wire at both ends and solder new wire in of same dimension as the old and hey presto we now have working heaters
Re: no heater
Woo-hoo!! Just in time for spring
- 1.8 8v
Re: no heater
and a lot cheaper than the £150 quid a leccy wanted to do it ffs
